modem radiowy
piotreksp
modem radiowy
Postautor: piotreksp » 10 maja 2007, o 10:14
radiomodem, jak to bedzie wygladac w icc avr? nie rozpoznaje mi biblioteki cc1000.h ;-)
#include <io2313v.h> #include <macros.h> #include "cc1000.h" #pragma interrupt_handler ObslugaPrzerwania_int0: iv_INT0 #define ROZMIAR_NAGLOWKA 4 // 4 bytes header #define ROZMIAR_BUFORA_TX 32 // Size (in bytes) of transmit buffer #define ROZMIAR_BUFORA_RX 32 // Size (in bytes) of receive ring-buffer #define DLUGOSC_PREAMBULY 4 // Number of bytes of preamble to send */ #define BITY_PREAMBULY_WYMAGANE 4 /* Number of bits required in addition to */ /* the initial 8 bits for the preamble to be */ /* accepted */ #define ZNACZNIK1 0x33 /* First byte of unique identifier */ #define ZNACZNIK2 0xCC /* Second byte of unique identifier */ #define FALSZ 0 #define PRAWDA (!FALSZ) #define ON PRAWDA #define OFF FALSZ char RejestrDanych; volatile char BuforTX[ROZMIAR_BUFORA_TX]; volatile char BuforRX[ROZMIAR_BUFORA_RX]; // Index pointers for use with buffers volatile char LicznikBuforaTX; char LicznikOdczytuBuforaRX; volatile char LicznikZapisuBuforaRX; // Counter variables char LiczbaPreambul; char BladPreambuly; char LicznikBajtow; char LicznikBitow; char k_nad=0; volatile char LiczbaBajtowDoWyslania; volatile char LiczbaBajtowDoOdebrania; // State variable stores the current state of the state machine enum TypStanu {NADAWANIE=0,ODBIOR=1,BEZCZYNNY=2} Stan; // This variable stores the state to switch to // It is updated by the interrupt routine, while the main program // does the actual state switch volatile enum TypStanu NastepnyStan; // This struct stores various flags in a space-efficient manner //struct { //unsigned PreambleFound:1,ZNACZNIK1Found:1,LastPreambleBit:1,LockAverage:1,UnlockAverage:1;} flagi; volatile unsigned char PreambulaZnaleziona; // This routine initialises the TX buffer at startup void PrzygotowanieBuforaTX(void) { char i; // Put preamble into buffer for (i=0;i<DLUGOSC_PREAMBULY;i++) { BuforTX[i]=0xAA; } BuforTX[DLUGOSC_PREAMBULY]=ZNACZNIK1; // First byte of unique identifier BuforTX[DLUGOSC_PREAMBULY+1]=ZNACZNIK2; // Second byte of unique identifier BuforTX[DLUGOSC_PREAMBULY+2]=0x00; // Unit address BuforTX[DLUGOSC_PREAMBULY+3]=0x00; // Default : no data } #define PALE 3 // PORTD, pin 3 #define PDATA 4 // PORTD, pin 4 #define PCLK 5 // PORTD, pin 5 #define DCLK 2 // PORTD, pin 2 #define DIO 6 // PORTD, pin 6 #define RTS 2 // PORTB, pin 1 #define CTS 1 // PORTB, pin 2 #define CAL_TIMEOUT 0xFF #define LOCK_TIMEOUT 0xFF /* Contents of CURRENT register for TX and RX, use SmartRF(R) Studio */ /* to find values for your application */ #define TX_CURRENT 0x81 #define RX_CURRENT 0x44 /* Contents of PLL register for TX and RX, use SmartRF(R) Studio */ /* to find values for your application */ #define TX_PLL 0x48 #define RX_PLL 0x48 #define PA_VALUE 0xFF /****************************************************************************/ /* This routine sends new configuration data to the CC1000 */ /* Based on bit bashing (general I/O pin use) */ /****************************************************************************/ void ConfigureCC1000(char addr, char data) //short Configuration[]) { char BitCounter; //char WordCounter; //short Data; char adres; char dana; //PORTB&=~(1<<0); //(****) PORTD|=(1<<PALE); //PALE=1 //for (WordCounter=0;WordCounter<Count;WordCounter+=2) //{ //adres=adres_i_dane[WordCounter]; adres=addr; adres=adres<<1; //dana=adres_i_dane[WordCounter+1]; dana=data; PORTD&=~(1<<PALE); // PALE=0 /* Send address bits */ for (BitCounter=0;BitCounter<7;BitCounter++) { PORTD|=(1<<PCLK); // PCLK=1 if ((adres&0x80)==0) { PORTD&=~(1<<PDATA); // PDATA=0 } else { PORTD|=(1<<PDATA); // PDATA=1 } adres=adres<<1; PORTD&=~(1<<PCLK); //PCLK=0; } /* Send read/write bit */ /* Ignore bit in data, always use 1 */ PORTD|=(1<<PCLK); //PCLK=1 PORTD|=(1<<PDATA); //PDATA=1 PORTD&=~(1<<PCLK); //PCLK=0 //Data=Data<<1; PORTD|=(1<<PCLK); //PCLK=1 PORTD|=(1<<PALE); //PALE=1 /* Send data bits */ for (BitCounter=0;BitCounter<8;BitCounter++) { PORTD|=(1<<PCLK); //PCLK=1 if ((dana&0x80)==0) { PORTD&=~(1<<PDATA); // PDATA=0 } else { PORTD|=(1<<PDATA); // PDATA=1 } dana=dana<<1; PORTD&=~(1<<PCLK); //PCLK=0 } PORTD|=(1<<PCLK); //PCLK=1 //} /* Finished with word */ } /****************************************************************************/ /* This routine writes to a single CC1000 register */ /****************************************************************************/ void WriteToCC1000Register(char addr, char data) { //short val; //val=(addr&0x7F)<<9 | (data&0xFF); ConfigureCC1000(addr,data); } /****************************************************************************/ /* This routine writes to a single CC1000 register, with data and address */ /* given in the same variable */ /****************************************************************************/ /* void WriteToCC1000RegisterWord(short addranddata) { ConfigureCC1000(1,&addranddata); } /****************************************************************************/ /* This routine reads from a single CC1000 register */ /****************************************************************************/ char ReadFromCC1000Register(char addr) { char BitCounter; char Data; char Debug; //PORTB&=~(1<<0);//(****) PORTD|=(1<<PALE); //PALE=1 Data=addr<<1; PORTD&=~(1<<PALE); /* Send address bits */ for (BitCounter=0;BitCounter<7;BitCounter++) { PORTD|=(1<<PCLK); // PCLK=1 if ((Data&0x80)==0) { PORTD&=~(1<<PDATA); // PDATA=0 } else { PORTD|=(1<<PDATA); // PDATA=1 } Data=Data<<1; PORTD&=~(1<<PCLK); //PCLK=0; } /* Send read/write bit */ /* Ignore bit in data, always use 0 */ PORTD|=(1<<PCLK); //PCLK=1 PORTD&=~(1<<PDATA); //PDATA=0 PORTD&=~(1<<PCLK); //PCLK=0 PORTD|=(1<<PCLK); //PCLK=1 PORTD|=(1<<PALE); //PALE=1 //PORTB|=(1<<0); //(****) /* Receive data bits */ PORTD|=(1<<PDATA); //PDATA=1 DDRD&=~(1<<PDATA); /* Set up PDATA as an input */ for (BitCounter=0;BitCounter<8;BitCounter++) { PORTD&=~(1<<PCLK); //PCLK=0 Data=Data<<1; Debug=(1<<PDATA); if ((PIND&Debug)==0) { Data&=0xFE; } else { Data|=0x01; } PORTD|=(1<<PCLK); //PCLK=1 } //PORTB&=~(1<<0);//(****) DDRD|=(1<<PDATA); /* Set up PDATA as an output again */ return Data; } /****************************************************************************/ /* This routine resets the CC1000, clearing all registers. */ /****************************************************************************/ void ResetCC1000(void) { char MainValue; MainValue=ReadFromCC1000Register(CC1000_MAIN); WriteToCC1000Register(CC1000_MAIN,MainValue & 0xFE); // Reset CC1000 WriteToCC1000Register(CC1000_MAIN,MainValue | 0x01); // Bring CC1000 out of reset } /****************************************************************************/ /* This routine calibrates the CC1000 */ /* Returns 0 if calibration fails, non-zero otherwise. Checks the LOCK */ /* to check for success. */ /****************************************************************************/ char CalibrateCC1000(void) { unsigned char TimeOutCounter,j; WriteToCC1000Register(CC1000_PA_POW,0x00); // Turn off PA to avoid spurs // during calibration in TX mode WriteToCC1000Register(CC1000_CAL,0xA6); // Start calibration // Wait for calibration complete for(TimeOutCounter=CAL_TIMEOUT,j=0; ((ReadFromCC1000Register(CC1000_CAL)&0x08)==0)&&(TimeOutCounter>0); j++) { if (j==255){TimeOutCounter--;} } // Wait for lock for(TimeOutCounter=LOCK_TIMEOUT,j=0; ((ReadFromCC1000Register(CC1000_LOCK)&0x01)==0)&&(TimeOutCounter>0); j++) { if (j==255){TimeOutCounter--;} } WriteToCC1000Register(CC1000_CAL,0x26); /* End calibration */ WriteToCC1000Register(CC1000_PA_POW,PA_VALUE); /* Restore PA setting */ return ((ReadFromCC1000Register(CC1000_LOCK)&0x01)==1); } /****************************************************************************/ /* This routine puts the CC1000 into RX mode (from TX). When switching to */ /* RX from PD, use WakeupC1000ToRX first */ /****************************************************************************/ void SetupCC1000RX(char RXCurrent) { unsigned char i,j; //char lock_status; WriteToCC1000Register(CC1000_MAIN,0x11); // Switch into RX, switch to freq. reg A WriteToCC1000Register(CC1000_PLL,RX_PLL); // Use RX refdiv setting WriteToCC1000Register(CC1000_CURRENT,RXCurrent); // Program VCO current for RX // Wait 250us before monitoring LOCK for (i=0;i<4;i++) { for(j=0;j<205;j++);} // Wait for lock /*for(i=LOCK_TIMEOUT,j=0; ((ReadFromCC1000Register(CC1000_LOCK)&0x01)==0)&&(i>0); j++) { if (j==255){i--;} } /* // If PLL in lock if ((ReadFromCC1000Register(CC1000_LOCK)&0x01)==0x01){ // Indicate PLL in LOCK lock_status = LOCK_OK; // Else (PLL out of LOCK) }else{ // If recalibration ok if(CalibrateCC1000()){ // Indicate PLL in LOCK lock_status = LOCK_RECAL_OK; // Else (recalibration failed) }else{ // Reset frequency syncthesizer (ref.: Errata Note 01) ResetFreqSynth(); // Indicate PLL out of LOCK lock_status = LOCK_NOK; } } // Return LOCK status to application return (lock_status);*/ } /****************************************************************************/ /* This routine puts the CC1000 into TX mode (from RX). When switching to */ /* TX from PD, use WakeupCC1000ToTX first */ /****************************************************************************/ void SetupCC1000TX(char TXCurrent) { unsigned char i,j; //char lock_status; WriteToCC1000Register(CC1000_PA_POW,0x00); // Turn off PA to avoid frequency splatter WriteToCC1000Register(CC1000_MAIN,0xE1); // Switch into TX, switch to freq. reg B WriteToCC1000Register(CC1000_PLL,TX_PLL); // Use TX refdiv setting WriteToCC1000Register(CC1000_CURRENT,TXCurrent); // Program VCO current for TX // Wait 250us before monitoring LOCK for (i=0;i<4;i++) { for(j=0;j<205;j++);} // Wait for lock //for(i=LOCK_TIMEOUT; ((ReadFromCC1000Register(CC1000_LOCK)&0x01)==0)&&(i>0); i--); /*for(i=LOCK_TIMEOUT,j=0; ((ReadFromCC1000Register(CC1000_LOCK)&0x01)==0)&&(i>0); j++) { if (j==255){i--;} } /* // If PLL in lock if ((ReadFromCC1000Register(CC1000_LOCK)&0x01)==0x01){ // Indicate PLL in LOCK lock_status = LOCK_OK; // Else (PLL out of LOCK) }else{ // If recalibration ok if(CalibrateCC1000()){ // Indicate PLL in LOCK lock_status = LOCK_RECAL_OK; // Else (recalibration failed) }else{ // Reset frequency syncthesizer (ref.: Errata Note 01) ResetFreqSynth(); // Indicate PLL out of LOCK lock_status = LOCK_NOK; } } // Increase output power */ WriteToCC1000Register(CC1000_PA_POW,PA_VALUE); // Restore PA setting // Return LOCK status to application //return (lock_status);*/ } /****************************************************************************/ /* This routine puts the CC1000 into power down mode. Use WakeUpCC1000ToRX */ /* followed by SetupCC1000RX or WakeupCC1000ToTX followed by SetupCC1000TX */ /* to wake up from power down */ /****************************************************************************/ void SetupCC1000PD(void) { WriteToCC1000Register(CC1000_MAIN,0x3F); // Put CC1000 into power-down WriteToCC1000Register(CC1000_PA_POW,0x00); // Turn off PA to minimise current draw } /****************************************************************************/ /* This routine wakes the CC1000 up from PD mode to RX mode, call */ /* SetupCC1000RX after this routine is finished. */ /****************************************************************************/ /* void WakeUpCC1000ToRX(char RXCurrent) { int i; WriteToCC1000Register(CC1000_MAIN,0x3B); // Turn on xtal oscillator core WriteToCC1000Register(CC1000_CURRENT,RXCurrent); // Program VCO current for RX WriteToCC1000Register(CC1000_PLL,RX_PLL); // Use RX refdiv setting // Insert wait routine here, must wait for xtal oscillator to stabilise, // typically takes 2-5ms. for (i=0;i<8192;i++); WriteToCC1000Register(CC1000_MAIN,0x39); // Turn on bias generator // Wait for 250us, insert wait loop here for (i=0;i<820;i++); WriteToCC1000Register(CC1000_MAIN,0x31); // Turn on frequency synthesiser } /****************************************************************************/ /* This routine wakes the CC1000 up from PD mode to TX mode, call */ /* SetupCC1000TX after this routine is finished. */ /****************************************************************************/ void WakeUpCC1000ToTX(char TXCurrent) { unsigned char i,j; WriteToCC1000Register(CC1000_MAIN,0xFB); // Turn on xtal oscillator core WriteToCC1000Register(CC1000_CURRENT,TXCurrent); // Program VCO current for TX WriteToCC1000Register(CC1000_PLL,TX_PLL); // Use TX refdiv setting // Insert wait routine here, must wait for xtal oscillator to stabilise, // typically takes 2-5ms. for (i=0;i<64;i++) { for(j=0;j<255;j++);} WriteToCC1000Register(CC1000_MAIN,0xF9); // Turn on bias generator // Wait for 250us, insert wait loop here for (i=0;i<4;i++) { for(j=0;j<205;j++);} WriteToCC1000Register(CC1000_PA_POW,PA_VALUE); // Turn on PA WriteToCC1000Register(CC1000_MAIN,0xF1); // Turn on frequency synthesiser } /****************************************************************************/ /* This routine locks the averaging filter of the CC1000 */ /****************************************************************************/ /* void AverageManualLockCC1000(void) { WriteToCC1000Register(CC1000_MODEM1,0x19); } /****************************************************************************/ /* This routine unlocks the averaging filter of the CC1000 */ /****************************************************************************/ /* void AverageFreeRunCC1000(void) { WriteToCC1000Register(CC1000_MODEM1,0x09); } /****************************************************************************/ /* This routine sets up the averaging filter of the CC1000 for automatic */ /* lock. This can be used in polled receivers. */ /****************************************************************************/ /* void AverageAutoLockCC1000(void) { WriteToCC1000Register(CC1000_MODEM1,0x01); } /****************************************************************************/ /* This routine reads the current calibration values from the CC1000 */ /****************************************************************************/ /* void ReadCurrentCalibration(char *val1, char *val2) { *val1=ReadFromCC1000Register(CC1000_TEST0); *val2=ReadFromCC1000Register(CC1000_TEST2); } /****************************************************************************/ /* This routine overrides the current calibration of the CC1000 */ /****************************************************************************/ /* void OverrideCurrentCalibration(char val1, char val2) { WriteToCC1000Register(CC1000_TEST5,(val1&0x0F)|0x10); WriteToCC1000Register(CC1000_TEST6,(val2&0x1F)|0x20); } /****************************************************************************/ /* This routine stops override of the CC1000 calibration values */ /****************************************************************************/ /* void StopOverridingCalibration(void) { WriteToCC1000Register(CC1000_TEST5,0x00); WriteToCC1000Register(CC1000_TEST6,0x00); } /****************************************************************************/ /* This CC1000 frequency synthesizer */ /****************************************************************************/ /* void ResetFreqSynth(void) { char modem1_value; modem1_value = ReadFromCC1000Register(CC1000_MODEM1)&~0x01; WriteToCC1000Register(CC1000_MODEM1,modem1_value); WriteToCC1000Register(CC1000_MODEM1,modem1_value|0x01); } /****************************************************************************/ //================================================================================ // This routine handles setup needed when changing states void ZmienStan(void) { switch (NastepnyStan) { case ODBIOR: if (Stan==NADAWANIE) { MCUCR = 0x03; /* INT on rising edge */ PORTD&=~(1<<DIO); DDRD&=~(1<<DIO); /* Set DIO as input */ SetupCC1000RX(RX_CURRENT); //PORTB|=(1<<0);//(****) } Stan=ODBIOR; PORTB|=(1<<7);//SET_RXLED(ON); PORTB&=~(1<<3);//SET_TXLED(OFF); PORTB&=~(1<<5); PORTB|=(1<<2); // READY=1; // HW Handshake : Not Ready LicznikBitow=0; LicznikBajtow=0; break; case NADAWANIE: if (Stan!=NADAWANIE) { //PORTB&=~(1<<0);//(****) //CLI(); //GIMSK=0x00; //MCUCR = 0x00; MCUCR = 0x02; //GIMSK=0x40; /* INT on falling edge */ //SEI(); DDRD|=(1<<DIO); /* Set DIO as output */ SetupCC1000TX(TX_CURRENT); } Stan=NADAWANIE; PORTB&=~(1<<7);//SET_RXLED(OFF); PORTB|=(1<<3); //SET_TXLED(ON); PORTB&=~(1<<5); //PORTB|=(1<<2); // READY=1; // HW Handshake : Not Ready //UCR&=0x7F;//RXCIE=0; // Disable UART Interrupts LiczbaBajtowDoWyslania=LicznikBuforaTX; // Number of bytes to send BuforTX[DLUGOSC_PREAMBULY+3]=LiczbaBajtowDoWyslania-ROZMIAR_NAGLOWKA-DLUGOSC_PREAMBULY; //BuforTX[DLUGOSC_PREAMBULY+3]=1; // (****) LicznikBuforaTX=0; LicznikBitow=0; RejestrDanych=BuforTX[LicznikBuforaTX++]; //k_nad=0; //while (k_nad==0); break; case BEZCZYNNY: if (Stan==NADAWANIE) { MCUCR = 0x03; /* INT on rising edge */ PORTD&=~(1<<DIO); DDRD&=~(1<<DIO); /* Set DIO as input */ SetupCC1000RX(RX_CURRENT); //PORTB|=(1<<0);//(****) } Stan=BEZCZYNNY; PORTB&=~(1<<7);//SET_RXLED(OFF); PORTB&=~(1<<3); //SET_TXLED(OFF); PORTB|=(1<<5); PORTB&=~(1<<2);// READY=0; // HW Handshake : Ready //UCR|=0x80;//RCIE=1; // Enable UART Interrupts LicznikBuforaTX=ROZMIAR_NAGLOWKA+DLUGOSC_PREAMBULY; LiczbaPreambul=0; BladPreambuly=0; PreambulaZnaleziona=0; //ZNACZNIK1Found=FALSZ; break; } } /* void inicjalizacja(void) { unsigned char i; DDRB = 0xff; PORTB&=~(1<<CTS); // CTS=0 PORTB|=(1<<RTS); DDRB&=~(1<<RTS); CLI(); UCR = 0x00; //disable while setting baud rate UBRR = 0x54; //set baud rate UCR = 0x48; //enable MCUCR = 0x03; GIMSK = 0x00; TIMSK = 0x00; SEI(); //re-enable interrupts } */ //================================================================================ void programujRejestryCC1000(char CURRENT,char PLL) { WriteToCC1000Register(CC1000_FREQ_2A,0x42); WriteToCC1000Register(CC1000_FREQ_1A,0x20); WriteToCC1000Register(CC1000_FREQ_0A,0x00); WriteToCC1000Register(CC1000_FREQ_2B,0x42); WriteToCC1000Register(CC1000_FREQ_1B,0x18); WriteToCC1000Register(CC1000_FREQ_0B,0xE4); WriteToCC1000Register(CC1000_FSEP1, 0x02); WriteToCC1000Register(CC1000_FSEP0, 0x80); WriteToCC1000Register(CC1000_CURRENT,CURRENT); WriteToCC1000Register(CC1000_FRONT_END,0x12); WriteToCC1000Register(CC1000_PA_POW, PA_VALUE); WriteToCC1000Register(CC1000_PLL, PLL); WriteToCC1000Register(CC1000_LOCK, 0x10); WriteToCC1000Register(CC1000_CAL, 0x26); WriteToCC1000Register(CC1000_MODEM2, 0x8E); WriteToCC1000Register(CC1000_MODEM1, 0x69); WriteToCC1000Register(CC1000_MODEM0, 0x27); WriteToCC1000Register(CC1000_MATCH, 0x70); WriteToCC1000Register(CC1000_FSCTRL, 0x01); WriteToCC1000Register(0x1C,0x00); WriteToCC1000Register(0x42,0x25); } void ObslugaPrzerwania_int0(void) { /* This function must execute as fast as possible. Therefore, as much processing as possible is left to the main program */ switch (Stan) { case NADAWANIE: /* Write data to CC1000 */ if ((RejestrDanych&0x80)==0){PORTD&=~(1<<DIO);} else {PORTD|=(1<<DIO);}; //DIO=ShiftRegMSB; RejestrDanych=RejestrDanych<<1; LicznikBitow++; if (LicznikBitow==1) { if (LicznikBuforaTX>LiczbaBajtowDoWyslania) { NastepnyStan=BEZCZYNNY; //k_nad=1; break; } } if (LicznikBitow==8) { LicznikBitow=0; RejestrDanych=BuforTX[LicznikBuforaTX++]; } break; case ODBIOR: /* Read data from CC1000 */ RejestrDanych=RejestrDanych<<1; if ((PIND&(1<<DIO))==0){RejestrDanych|=0x01;} else {RejestrDanych&=0xFE;}//ShiftRegLSB=~DIO; LicznikBitow++; /* Byte received? */ if (LicznikBitow==8) { LicznikBitow=0; /* The three first bytes must be handled in a special manner */ switch (LicznikBajtow) { case 0 : // First byte (second part of SOF) if (RejestrDanych!=ZNACZNIK2) NastepnyStan=BEZCZYNNY; break; case 1 : // Second byte is address // Addressing not implemented break; case 2 : // Third byte is packet size, store this LiczbaBajtowDoOdebrania=RejestrDanych; if (LiczbaBajtowDoOdebrania>ROZMIAR_BUFORA_TX){ // If invalid length, ignore message LiczbaBajtowDoOdebrania=0;} break; default : // Rest of the packet is data, store it in the receive buffer BuforRX[LicznikZapisuBuforaRX]=RejestrDanych; // Increase counter, wrap around when we've reached end of buffer // LicznikZapisuBuforaRX=(LicznikZapisuBuforaRX+1)%ROZMIAR_BUFORA_RX; LicznikZapisuBuforaRX++; LicznikZapisuBuforaRX&=0x1F; } if (LicznikBajtow>=LiczbaBajtowDoOdebrania+2) { //UnlockAverage=1; NastepnyStan=BEZCZYNNY; } LicznikBajtow++; } break; case BEZCZYNNY: /* Read data from CC1000 */ RejestrDanych=RejestrDanych<<1; if ((PIND&(1<<DIO))==0){RejestrDanych|=0x01;} else {RejestrDanych&=0xFE;} //ShiftRegLSB=~DIO; // Polarity must be inverted if using high-side LO LicznikBitow++; /* If preamble has been found */ if (PreambulaZnaleziona==1) { /* Look for SOF/unique identifier */ if (RejestrDanych==ZNACZNIK1) { // If SOF found, go into RX mode NastepnyStan=ODBIOR; } /* Are we still receiving the preamble? */ else if ((RejestrDanych==0x55)||(RejestrDanych==0xAA)) { ; /* If so, do nothing */ } /* If we are not receiving a correct preamble, declare an error */ else if (BladPreambuly==0) { BladPreambuly++; } if (BladPreambuly>0) /* Increase the error counter regardless of bits read if */ /* we have found en error */ BladPreambuly++; /* Once an error condition has occurred, a correct SOF must be */ /* found within 9 bits (we increment by 2 at the first bit), */ /* otherwise we abort and start looking for the preamble again */ if (BladPreambuly>10) { PreambulaZnaleziona=0; // UnlockAverage=1; } } /* If preamble has not been found */ else { /* If valid preamble, increase counter */ if ((RejestrDanych==0x55)||(RejestrDanych==0xAA)) { LiczbaPreambul++; //PORTB^=(1<<6); } /* If not, reset counter */ else { LiczbaPreambul=0; } /* If preamble requirement has been reached, declare that preamble */ /* has been found */ if (LiczbaPreambul>=BITY_PREAMBULY_WYMAGANE) { PreambulaZnaleziona=1; // LockAverage=1; BladPreambuly=0; } } break; default: // If something goes haywire, get back into a known state NastepnyStan=BEZCZYNNY; break; } //INTF=0; } //================================================================================ void putchar(char ch) { while(!(USR & (1<<UDRE))); /*TXIF==0 Wait for buffer to be empty */ UDR=ch; } //================================================================================ /* #pragma interrupt_handler uart0_rx_isr:8 void uart0_rx_isr(void) { BuforTX[LicznikBuforaTX++]=UDR; TCCR0 = 0x00; //stop timer TCNT0 = 0x00; //set count TCCR0 = 0x05; //start timer //uart has received a character in UDR } */ void main(void) { char dummy; unsigned char i,j; DDRB=0xFF; //DDRD=0xFF; PORTD=0x00; DDRD|=(1<<PALE); DDRD|=(1<<PDATA); DDRD|=(1<<PCLK); UCR = 0x00; //disable while setting baud rate UBRR = 0x14; //set baud rate 3.2768MHz, 9600baud UCR = 0x18; //enable TCCR0 = 0x00; //stop timer TCNT0 = 0x95; //set count //TCCR0 = 0x05; //start timer PORTD|=(1<<PALE); //PALE=1//PALE=1; LicznikOdczytuBuforaRX=0; LicznikZapisuBuforaRX=0; SetupCC1000PD(); ResetCC1000(); for (i=0;i<64;i++) { for(j=0;j<255;j++);} programujRejestryCC1000(TX_CURRENT,TX_PLL); WakeUpCC1000ToTX(TX_CURRENT); SetupCC1000TX(TX_CURRENT); //MCUCR = 0x02; /* INT on falling edge */ //DDRD|=(1<<DIO); /* Set DIO as output */ CalibrateCC1000(); // Calibration data is stored in the chip indexed by the selected frequency register programujRejestryCC1000(RX_CURRENT,RX_PLL); SetupCC1000RX(RX_CURRENT); //MCUCR = 0x03; /* INT on rising edge */ //DDRD&=~(1<<DIO); // Set DIO as input CalibrateCC1000(); PORTB|=(1<<4); // Now the CC1000 is calibrated for both RX and TX, we do not need to recalibrate // unless the frequency is changed, the temperature changes by 40 degrees C // or if the supply voltage changes by more than 0.5V // Force update Stan=NADAWANIE; NastepnyStan=BEZCZYNNY; PrzygotowanieBuforaTX(); // Set all buttons to light, if we want to turn them off, we set them as inputs to avoid // the output being shorted to VDD if a button is pressed /* AWAKE=0; SYNC=0; */ GIMSK = 0x40; SEI(); while(1) { /* If state change, handle it */ //PORTB^=(1<<6); if (Stan!=NastepnyStan) ZmienStan(); /* If data in receive buffer, write it to the serial port */ if (LicznikOdczytuBuforaRX!=LicznikZapisuBuforaRX) { putchar(BuforRX[LicznikOdczytuBuforaRX]); // Increase read index, wrap around when reached end of buffer //LicznikOdczytuBuforaRX=(LicznikOdczytuBuforaRX+1)%ROZMIAR_BUFORA_RX; LicznikOdczytuBuforaRX++; LicznikOdczytuBuforaRX&=0x1F; } if ((USR & (1<<RXC))!=0) { //RCIF==1 // UART receive interrupt. PC has sent data to us. //PORTB^=(1<<5); if (Stan==BEZCZYNNY) { // Only handle data if idle TCCR0 = 0x00; //stop timer TCNT0 = 0x95; //set count TCCR0 = 0x05; //start timer BuforTX[LicznikBuforaTX++]=UDR; // IMPORTANT : We may have another interrupt or two occur before we can change mode // Therefore, leave safety margin! if (LicznikBuforaTX>=(ROZMIAR_BUFORA_TX-3)) { // Change mode early to have safety margin PORTB|=(1<<2); // READY=1; // HW Handshake : Not Ready NastepnyStan=NADAWANIE; } //PORTB&=~(1<<5); } } if ((TIFR&0x02)!=0) { //TMR2IF==1 // Timer 2 interrupt. TX timer has timed out. TCCR0 = 0x00; //TMR2ON=0; // Turn off timer 2 NastepnyStan=NADAWANIE; TIFR|=(1<<TOV0);//TMR2IF=0; } } }
Kod proszę ujmować w tagi code. radzio.
Ostatnio zmieniony 1 sty 1970, o 01:00 przez piotreksp, łącznie zmieniany 1 raz.
Wróć do „AVR/AVR32”
