Szukam najprostrzego schematu..
Moderator:Jacek Bogusz
Tidus
Postautor: Tidus » 26 kwie 2007, o 07:43
Witam pare dni temu stałem się nabywcom programatora WILLEM 7.1 który obsługuje takie mikrokontroler:
EPROM 27C64, 27C128, 27C256, 27C512, 27C010, 27C020, 27C040,27C1001
M27C1001, M27C2001, M27C4001
27C080 (A19) ,M27C801,M87C257
2716(Vpp25V),2732, (adapter DIP24)
2764, 27128, 27256, 27512, 27010,
Vpp12.5V (21Vpp Modify Circuit)
EEPROM 28C65,28C64, 28C128, 28C256,28C512, 28C010, 28C020, 28C040
M28C16A/17A (DIP28)
(Adapter or Jumper) 28C16,XLS2816 (DIP24)
FLASH Memory 28F64, 28F128, 28F256, 28F512,28F010, 28F020
MX26C1000, MX26C2000, MX28F1000, MX28F2000
Am28F256A, Am28F512A, Am28F010A, Am28F020A (New command erase/prog.)
-- intel ---
i28F001BX, 28F004, 28F008, 28F016
FLASH Memory 29F64, 29F128, 29F256, 29F512,29F010, 29F020, 29F040, 29F080
29F001,29F002, 29F004, 29F008, 29F016, 29F032
Serial (I2C) EEPROM
24Cxx 24C02,24C04,24C08,24C16, 85C72, 85C82, 85C92
--- page write ----
24C32,24C64,24C128,24C256,24C512
Microwire EEPROM
<------ Data 8bit -----> (pin 6 ->ORG. [Schematic connect to GND])
93C06, 93C46, 93LC46, 93C56, 93C57,
93C66, 93C76, 93C86 (8bit), AT59C11, AT59C22, AT59C13
CAT35C102, CAT35C104, CAT35C108 (pullup pin7)
<------Data 16bit------> (pin 6 ->NC [No Connect])
93C06A ,93C46X,93C56,93C66,93C76,93C86 (NS)
MicroChip PIC 16C84, 16F84, 16F84A ,16F627/16F628
12C508/A, 12C509/A, 12CE518, 12CE519, 16C505
16C620 16C621, 16C622, 16CE623, 16CE624, 16CE625, 16C710/711
---ICSP connector----
16F870, 16F871, 16F872, 16F873, 16F874, 16F876, 16F877
PIC16F873A, PIC16F874A, PIC16F876A, PIC16F877A
Atmel Flash Memory
(Sector Programming)
(Software Data Protection) AT29C256, AT29C512,AT29C010A, AT29C020, AT29C040,AT29C040A
W29EE512,W29EE011, W29EE012, W29C020(128),W29C040
PH29EE010(W29EE011)
ASD AE29F1008 (AT29C010), AE29F2008 (AT29C020)
Ver 0.992 up(DOS). Can run under win9x
(disable prog. CPUIdle or CPUCool)
Atmel Flash Memory
AT49Fxxx (Subset 29Fxxx)
(Byte-by-Byte Programming)
(Software Data Protection) Command seq. 5555/AA, 2AAA/55, 5555/A0
AT49F512, AT49F010, AT49F020, AT49F040
SST39SF010, SST3S9F020 ,SST39SF040
AT49F001,AT49F002 , AT49F008A
Command seq. 555/AA, 2AA/55, 555/A0
Am29F512, Am29F010, Am29F020, Am29F040,HY29F080
29F002, 29F002T, Pm29F002T
Serial Peripheral Interface (SPI)
EEPROM Mode0 (0,0)
AT25xxx, W95xxx [Atmel] AT25010,020, 040 (A8-A0)
AT25080, 160, 320, 640, 128, 256 (A15-A0)
[ST] W95010....256, Microchip 25x010 - 25x640
--- Byte programming
25010,25020,25040
--- Page programming
25C080,25C160,25C320,25C640,25C128,25C256,25C512
AT25HP256,AT25HP512
AT25HP1024 (24bit address)
-- CAT64LCxxx (16bit DATA IN/OUT) use Socket 93Cxxx
CAT64LC010, CAT64LC020, CAT64LC040
Atmel EEPROM (page prog.)
(Software Data Protection) AT28C256, AT28C010, AT28C040
Nonvaltile SRAM (DS12xx) DS1220,DS1225Y, DS1230Y/AB, DS1245Y/AB, DS1249Y/AB
static RAM (Test RAM) 6116, 6264, 62256, 62512, 628128
EPROM winbond,SST
Electrical Erase Chip W27E512, W27E010, W27C010, W27C020, W27C040
SST27SF256, SST27SF512, SST27SF010, SST27SF020
MX26C4000
Vcc = 3.3-3.6V SST37VF512, SST37VF010, SST37VF020, SST37VF040
Flash Memory SST,Sanyo SST28SF040A ,LE28F4001
Firmware Hub / LPC FLASH
Adapter Firmware Hub/LPC (PLCC32) (PP mode) (3.3V)
-- Firmware Hub
82802AB, 82802AC, AT49LW040, AT49LW080
SST49LF002A, SST49LF003A, SST49LF004A, SST49LF008A
W49V002FA, W39V040FA
-- LPC flash
SST49LF020, SST49LF040
W49V002A, W39V040A
I związku z tym szukam jakiegoś najprostrzego schematu z zastosowaniem jakiegoś prostego mikrokontrolera do zaprogramowania najlepiej na diodach.
Jeśli ktoś może mi pomóc to z góry dzięki.
Pozdawiam Tidus
MDz
Postautor: MDz » 26 kwie 2007, o 12:40
Wymieniona lista zawiera przede wszystkim pamięci EPROM, flash-EPROM i EEPROM. Wprawdzie programując µC de facto wpisujesz program do jego wewnętrznej pamięci flash, jednak przeglądając (pobieżnie) willemową listę zauważyłem na niej tylko PIC-e Microchip-a:
MicroChip PIC 16C84, 16F84, 16F84A ,16F627/16F628 12C508/A, 12C509/A, 12CE518, 12CE519, 16C505 16C620 16C621, 16C622, 16CE623, 16CE624, 16CE625, 16C710/711 ---ICSP connector---- 16F870, 16F871, 16F872, 16F873, 16F874, 16F876, 16F877 PIC16F873A, PIC16F874A, PIC16F876A, PIC16F877A
Wygląda na to (nie znam Willem-a osobicie), że lista, którą podałeś obejmuje układy dające się wsadzić _bezpośrednio_ w programator.
Żaby zaprogramować coś z popularnych mikrokontrolerów ATMELa (AVR lub AT89...) potrzebujesz dodatkowych adapterów: Zobacz np.:
http://www.allegro.pl/item182501486_pro ... d_zif.html
http://www.willem.org -> http://www.willem.org/specs.htm
Albo programatora do programowania w systemie (ISP). Spójrz np. na schemat AVR-ISP (STK200) na stronie PonyProg-a:
http://www.lancos.com/prog.html
(Inna sprawa, że programator równoległy bywa pomocny, w razie gdy zrobisz błąd i zablokujesz procka podczas programowania ISP)
Trochę nie łapię o co Ci chodzi. Mógłbyś podkręcić jasność?
Czy szukasz jakiejś najprostszej aplikacji wykorzystującej mikrokontroler?
Czy "na diodach" oznacza "mrugającej diodami LED" ?
MDz
Tidus
Postautor: Tidus » 26 kwie 2007, o 16:21
Faktycznie nie dodałem listy mikroprocesorów które są obsługiwane za pomoncą adaptera a oto one:
Atmel AT89Cxx (MCS-51)
Adapter 32pin to MCS-51 Atmel Auto Setect
AT89C51,52,55, AT89LV51,52,55
AT89S8252 (8K+2K), AT89S53, AT89LS8252,AT89LS53
AT89C1051,AT89C2051,AT89C4051 (20pin)
AT89C51RC (32KB), AT89C55WD (6.2V)
SST89C54/58, SI89C52
Intel Auto Select
i87C51, i87C51FA, i87C51FB
i8xC51,i8xC52,i8xC54,i8xC58 (tWP = 100uS*25 Pulse)
Atmel AVR 8-bit RISC AT90Sxxx
(Parallel programming)
Adapter 32pin to MCS-51 (read,write,erase,verify,checkempty,Lockbits ,Fusebits) [Flash memory/EEPROM]
AT90S1200,AT90S2313
90S2333, 90S4433, 90S4414, 90S8515, 90S4434, 90S8535
reference AT90S2313 pin
Function Lockbit read AT90S2313 Errata Sheet.pdf
MCS-48,MCS-41
Adapter 32pin to MCS-48/41 ROM (read/verify)
P8048AH, P8049AH,P8050AH, P8042AH Vea = 12V
P8041, P8042
OTP (read/verify/Progam)
P8748,P8749H,P8742H Vea = 18V
EPROM (read/verify/Progam)
D8748,D8749,D8742,D8741, D8742 Vea = 18V
FLASH memory 8/16bit
Adapter (TSOP48) Am29F400,Am29F800,29F160,29F320 (read,write byte mode)
HY29F200, HY29F400, HY29F800 , AT49F2048A, AT49F4096A, AT49F8192A
FLASH memory 8/16bit (Vpp12V)
Adapter (TSOP48) i28F200,i28F400,i28F800,i28F160 (TSOP48)
28F001(DIP32 or PLCC32)
EPROM 16bit (DIP40) (1-4Mbit)
Adapter Eprom 16bit
Eprom only
27C1024 (27C210), 27C2048 (27C2002), 27C4096 (27C4002),
Schematic by Toomas Toots
(read,Program byte mode
by use Resister pull up Data Bus (0xFF), A0 select low or high byte)
EPROM 16bit (DIP42) (4-32Mbit)
Adapter Eprom DIP42
Eprom only
M27C400(DIP40), 27C800, 27C160, 27C322
Adapter (TSOP48LV) 29LV200, 29LV400,29LV800,29LV160,29LV320 (read,write byte mode)
P28F002BC
Adapter P28F002BC (DIP40)
BOOT BLOCK FLASH MEMORY
- P28F002BC
Ale niestety zakupienie tego adapterem to jak wiadomo dodatkowe koszta.
Nie dałoby sie jakoś samemu zrobić takiego adaptera??
MDz
Tak o to mi chodzi żeby przy zastosowaniu mikrokontrolera diody np: w odpowiedniej kolejności mrugały.
PZD Tidus
Wróć do „Poszukuję / kupię”
