struct st1 *w_str;
struct st1 str2;
str2 = *w_str; Kod: Zaznacz cały
str2.skladnik = 4;
struct st1 *w_str;
struct st1 str2;
str2.skladnik = 4;Kod: Zaznacz cały
struct PERSON {
char name [32];
int age;
struct PERSON person_info;
struct PERSON *ptrPerson_info;
struct PERSON other_info;
person_info.age = 10;
strcpy ( person_info.name, "Ola" );
ptrPerson_info = &person_info;
other_info = *ptrPerson_info;
printf ("%s %d \n", other_info.name, other_info.age );
( *ptrPerson_info ).age = 28;
strcpy ( ( *ptrPerson_info ).name , "Kama" );
// sprawdzenie
printf ("%s %d \n", person_info.name, person_info.age );
void main (void) {
struct SSS {
unsigned char m_f1;
unsigned char m_f2;
struct SSS var1;
struct SSS *pVar;
struct SSS var2;
pVar = &var1;
var2 = *pVar;
sprawdziłam jeszcze w uC/51...SDCC test.c:12: error 48: cannot assign values to aggregates
a przecież piszą, że uC/51 jest Ansi C....test.c 12: Error: unable to generate code for this expression
