Please help me for AVT868
preda_3
Postautor: preda_3 » 20 lip 2005, o 16:53
Dear..
I'm need and want to build project Programowany zegar for EP magazine 7/2000 please help for post it or send me hexcode for project by email thank you for advance
Best regard
preda_3
preda_panapan@yahoo.co.th
Postautor: ACeK » 20 lip 2005, o 17:40
:) try this :arrow: link and there zrodlo programu do mikroprocesorowego zegara LCD :wink:
:D
preda_3
Postautor: preda_3 » 20 lip 2005, o 18:29
I'm can't convert file.bas to hexcode please help me
radzio
Postautor: radzio » 20 lip 2005, o 18:47
Hex & bin file :
ZEGAR.zip
(4.75KiB)Pobrany 233 razy
a_antoniak
Re: Please help me for AVT868
Postautor: a_antoniak » 20 lip 2005, o 18:48
You have to use BASCOM 8051 to compile this source code.
Demo version is available here: http://www.mcselec.com/download_8051.htm or at http://www.ep.com.pl in Download section.
Demo version will be enough, although (as I remember) it has flash code size limit = 2kB (89C2051 has only 2kB of flash program memory).
radzio
Postautor: radzio » 20 lip 2005, o 18:58
This program use 2946 bytes of code memory and doesn't fit into AT89C2051. On title photo from this article is AT89C4051. Schematic has mistake -> in place of AT89C2051 should be AT89C4051.
Used ROM : &HB82 2946 (dec) > doesn't fit into selected codesize : 2048
Ostatnio zmieniony 21 lip 2005, o 12:24 przez radzio, łącznie zmieniany 3 razy.
a_antoniak
Postautor: a_antoniak » 20 lip 2005, o 19:06
That's the point! :)
preda_3
Thank you very much
Postautor: preda_3 » 20 lip 2005, o 20:13
Thank you radzio & a_antoniak for your help
Best regard
preda_3
M@rek
Postautor: M@rek » 21 lip 2005, o 08:51
Przepraszam że się wtroncam już zauważyłem ze to po angielsku ale z anglika zawsze byłem cienki :oops: i nic nie rozumiem :evil: .
Postautor: ACeK » 21 lip 2005, o 09:11
:) M@rek to najwyzszy czas bys sie zabral sie za angielski masz 14 lat to wcale nie jest za pozno a uwiez mi ze w tym swiecie (net) bez angielskiego to jak bez reki :wink:
:D
czarutek
Postautor: czarutek » 21 lip 2005, o 09:31
A bez polskiego no problems... ;)
a_antoniak
Postautor: a_antoniak » 21 lip 2005, o 11:35
M@rek - będąc aktywnym konstruktorem i zajmując się w Polsce elektroniką (która jest niezwykle czasochłonna i męczy głowę) nie da się tak po prostu nauczyć angielskiego w stopniu zaawansowanym, ktory pozwoli plynnie porozumiewac sie. Albo jedno - albo drugie (no, chyba że ktoś jest geniuszem językowym). Ludzie, którzy będąc w kraju nauczyli się super anglika poświęcają na to zwykle specjalne studia (anglistyka atp), a to praktycznie nie da się połączyć ze studiami techniczymi na których sypia się niekiedy po 4h/dobę.
Ale to NIE ZNACZY, że nie da się poznać tego języka w stopniu, który pozwoli w miare płynnie poruszać się po sieci i korzystać z ogromu przydatnych informacji które ZAWSZE publikowane są po angielsku. Niezależnie od tego jak wspaniałe publikacje ukazują się po polsku - to jest wciąż za mało.
Warto zaopatrzeć się w słownik (najlepiej program komputerowy) oraz w słownik techniczy (informatyczny).
A w ogóle najlepszą metodą nauki j. obcego jet pojechać na jakiś czas tam gdzie mówią w tym języku i dodatkowo brać lekcje. Niesie to jednak zwykle problemy pracowo-finansowe, o których tyle się dziś mówi że można zwymiotować.
czarutek
Postautor: czarutek » 21 lip 2005, o 11:52
... będąc aktywnym konstruktorem i zajmując się w Polsce elektroniką (która jest niezwykle czasochłonna i męczy głowę) nie da się tak po prostu nauczyć angielskiego w stopniu zaawansowanym ...
A polskiego jak widać się da... ;)
... Warto zaopatrzeć się w słownik (najlepiej program komputerowy) oraz w słownik techniczy (informatyczny).
Popieram. Ja się już dawno zdecydowałem w takie słowniki zaopatrzyć i bardzo często z nich korzystam... ;)
mirkap
Postautor: mirkap » 27 wrz 2005, o 07:49
skompilowałem, zaprogramowałem i nie działa
na wyświetlaczu same FF:FF:FF, w lowerline napis alarm: i na przemian miga ON i OFF. nic się nie da ustawić.
a czy może mi ktoś jeszcze wyjaśnić po co jest wyjście PCF nr 7 (INT) połaczone z P3.2 skoro w programie nie ma do tego odniesienia?
danio_ac
Postautor: danio_ac » 1 lut 2007, o 12:50
A u mnie na przemian wyświetla się:
****AVT-XXXX****
*****Witamy!*****
***BASCOM CLUB***
*****DESIGN******
Czym to może być spowodowane??
Wróć do „Kity AVT”
