manuale tel bezprzewodowych PHILIPS seria TD
PICIA
Postautor: PICIA » 12 gru 2004, o 10:14
jak w temacie-jesli komus bedzie potrzeba podesle
PHILIPS ELEGANCE 44 td9068_dfu_eng.pdf 146 427 2004-12-08 11:55 -a---
PHILIPS ELEGANCE 55 td9368_dfu_eng.pdf 246 865 2004-12-08 12:02 -a---
PHILIPS ELEGANCE td9363_dfu_eng.pdf 253 355 2004-12-08 12:02 -a---
PHILIPS ELEGANCE td9473_dfu_eng.pdf 482 271 2004-12-08 12:03 -a---
PHILIPS ICANA td5250_dfu_eng.pdf 1 407 097 2004-12-08 11:09 -a---
PHILIPS ICANA td5260_dfu_fra.pdf 1 425 786 2004-12-08 11:16 -a---
PHILIPS ICANA td5350_dfu_eng.pdf 2 423 689 2004-12-08 11:16 -a---
PHILIPS KALA 200 td6131_dfu_eng.pdf 815 547 2004-12-08 11:24 -a---
PHILIPS KALA 200 td6830_dfu_eng.pdf 1 549 439 2004-12-08 11:51 -a---
PHILIPS KALA td6120_dfu_eng.pdf 1 803 811 2004-12-08 11:21 -a---
PHILIPS KALA td6523_dfu_eng.pdf 1 939 212 2004-12-08 11:30 -a---
PHILIPS KALA td6822_dfu_eng.pdf 831 410 2004-12-08 11:49 -a---
PHILIPS KALA VOX 200 td6533_dfu_eng.pdf 924 627 2004-12-08 11:31 -a---
PHILIPS ONIS 2 td6311,6511_dfu_eng.pdf 2 279 912 2004-12-08 11:26 -a---
PHILIPS ONIS 200 td6331_dfu_eng.pdf 952 384 2004-12-08 11:27 -a---
PHILIPS ONIS 200 td6410_dfu_eng.pdf 3 013 351 2004-12-08 11:28 -a---
PHILIPS ONIS 200 td6831_dfu_eng.pdf 1 099 682 2004-12-08 11:52 -a---
PHILIPS ONIS MEMO td6411_pss_eng.pdf 582 834 2004-12-08 11:41 -a---
PHILIPS ONIS td6211_dfu_eng.pdf 3 013 351 2004-12-08 11:25 -a---
PHILIPS ONIS td6411_dfu_eng.pdf 3 013 351 2004-12-08 11:28 -a---
PHILIPS ONIS td6711_dfu_fra.pdf 2 922 544 2004-12-08 11:33 -a---
PHILIPS ONIX VOX td6611_dfu_eng.pdf 1 937 731 2004-12-08 11:31 -a---
PHILIPS PLUS KALA 200 td6133_dfu_eng.pdf 610 872 2004-12-08 11:24 -a---
PHILIPS SKIP 100 td9063_dfu_eng.pdf 275 610 2004-12-08 11:55 -a---
PHILIPS SKIP 300 td9137_dfu_eng.pdf 291 303 2004-12-08 11:56 -a---
PHILIPS SKIP 800 td9471_dfu_eng.pdf 423 082 2004-12-08 12:02 -a---
PHILIPS SONATA td5220_dfu_fra.pdf 1 149 867 2004-12-08 11:09 -a---
PHILIPS td6631_dfu_eng.pdf 952 384 2004-12-08 11:32 -a---
PHILIPS td6800,20,50_dfu_eng.pdf 970 247 2004-12-08 11:43 -a---
PHILIPS td6816_dfu_eng.pdf 908 659 2004-12-08 11:42 -a---
PHILIPS td9053_dfu_fra.pdf 148 194 2004-12-08 11:54 -a---
PHILIPS td9220_dfu_eng.pdf 295 023 2004-12-08 11:56 -a---
PHILIPS XALIO 200 d6031_dfu_eng.pdf 2 834 184 2004-12-08 11:20 -a---
PHILIPS XALIO VOX td6600_dfu_eng.pdf 3 161 415 2004-12-08 11:31 -a---
PHILIPS ZENIA td6326_dfu_eng.pdf 2 074 394 2004-12-08 11:27 -a---
PHILIPS ZENIA td6626_dfu_eng.pdf 2 074 394 2004-12-08 11:32 -a---
DOROTA
Re: manuale tel bezprzewodowych PHILIPS seria TD
Postautor: DOROTA » 17 mar 2007, o 10:34
[quote="PICIA"]jak w temacie-jesli komus bedzie potrzeba podesle
Witam,potrzebuję jakiejs rady co zrobić z telefonem-typ telefonu , jak wyżej ,który ostatnio mi szwankuje?
ucieka zasięg antenki,sam się rozłącza podczas rozmowy a nawet całkowicie się wył,tak , jakby został wypięty z sieci-brak na wyświetlaczu ikonki baterii :(
po chwili znowu jest ok,oczywiście na jakiś czas.....
co się mogła popsuć?
czy moge prosić o jakiś "trop" albo jakąs instrukcje?
dziekuję i pozdrawiam
[ Dodano: 18-03-2007, 09:02 ]
Czy ktoś tu zaglądnie i cos mi odpisze?
PICIA
re
Postautor: PICIA » 18 mar 2007, o 11:29
witam
instrukcje znajdziesz na moim Forum www.elektrotech.info
ps
jaki masz problem z tym aparatem??
DOROTA
Postautor: DOROTA » 18 mar 2007, o 11:46
Hej.
No właśnie taki,jaki opisałam.
Jak rozmawiam A NAWET WTEDY GDY Z NIEGO NIE KORZYSTAM,to zanika sygnał .Kiedy ja inicjuję połaczenie,to po prostu je rozłącza.Jeśli jednak ktoś do mnie dzwoni,to po zaniku "słyszalności",czasami udaje mi sie wciążz tą osobą rozmawiać-tak jakby zasięg powrócił,wszystko jest w porządku do następnej "niemiłej przerwy".Zauwazyłam też,że pomimo tego iż sygnał zanika,połaczenia przychodzące są rejestrowane ....-działą clip bez żadnego problemu . Ostatnio też wymieniałm akumulatorki,bo znajomy mi podpowiedział,że mogą być już za słabe, ale po zakupie nowych NI-MH wciąż jest tak samo :(
PICIA
re
Postautor: PICIA » 18 mar 2007, o 17:08
a co się dzieje na wyświetlaczu słuchawki ???? zanikaja napisy???
DOROTA
Postautor: DOROTA » 18 mar 2007, o 18:26
ZNIKA WSZYSTKO OPRÓCZ MIERNIKA BATERII.PODCZAS ROZMOWY,JAK TAK SIE DZIEJE,TO.....TYLKO MIGA ANTENKA I JEST CISZA.Podczas gdy miga antena, nie ma mozliwości wybierania numeru,brak sygnału.... Nie zawsze się to dzieje,ale są dni kiedy korzystanie z telefonu jest uciążliwe.
PICIA
re
Postautor: PICIA » 18 mar 2007, o 19:04
chy słuchawka zaliczyła upadek dość mocny???
kłania sie przelutowanie słuchawki-okolice procesora
DOROTA
Postautor: DOROTA » 18 mar 2007, o 19:17
NIE WIEM CZY MI UPADŁA.....MOŻE?
ale z tym przlutowaniem,to....chyba będę musiała poprosic jakiegoś faceta,bo sama,to....napewno zlutowałabym wszystko co się znajduje na płytce :)))
dzięki za podpowiedź
zyczę miłego wieczoru.
Użytkownicy przeglądający to forum: Majestic-12 [Bot] i 58 gości
